Hi I am new to this forum so a big hello to you all.
I have a new (61 plate) mondeo Titanium 2L 163BHP estate.
I noticed that it didnt have any side lights on appart from the Daytime running light that go dimm when the side lights are switced on!!
So as it was due its first service ( I do loads of miles) I took it to Ford.
On collecting it they told me thats how they were and didnt have side lights just the DRL's at half intensity.!!!! WHAT!!???
I was sure I have seen the side lights on prior to noticing it didnt have any???
any experts can offer any advise on this one??
the tail lights come on when the side lights are switched on.
DRLs replacing the parking lights (or side lights, as you Brits call it) is not something unique to the Mondeo, or to Ford for that matter.
The same is the case with other European car manufacturers, due to EU directives governing this area.
You can get a Mk4.5 without the DRLs too in some markets (including Ireland).
In those cases, there's a grille fitted in each of the slots under the headlamps, where the DRLs normally go.
As far as I've understood, such cars would come with parking lights in the headlamp housing.
Also, if you park up somewhere on the roadside, turn off the engine and lights, and then turn the indicator stalk to the side facing the road
(if the behaviour hasn't changed from Mk4 to Mk4.5), the DRL facing the road should light up at reduced intensity, along with the tail light on the same side.
Why would anyone need sidelights? Driving around with sidelights on is ridiculous, if visiblity is reduced you need your headlights on. You need to be seen. The truck driver needs to see you in his mirrors and sidelights just don't cut it.
I find the name "sidelights" quite misleading. Most other European countries call them parking lights.
This is specifically because they're not meant to be used when driving, only when parked up on the roadside.
(This is probably also why the DRLs go dim when you put the switch in sidelight mode)
I do agree with your comments about the ones who do drive around with only them on, though.
Correct SteveyG is bang on.
You are supposed to and can drive with just sidelights on in built up areas.
My point is that the DRL's are on very bright wihtout the swicth to side lights which means you also dont get any rear lights without the side lights on.
when you turn on the switch you get dimm DRL's and tail lights. Needed at times. But you would have thought that the DRl's would come on bright and not dimmer.
I also agree you need to be seen guys.
The set up seems wrong.- like max said why make the DRL;s dimmer when you put your lights on to make yourself more visable.
The reasoning is that the DRLs are actually very bright, but effectively unfocused. To be visible in daylight they must be bright, but they are too dazzling at night time to other drivers at the same brightness.
In 'dim' mode, they are still as bright as normal 5W incandescent lamps in my opinion
Is it possible to remove the "Caps" and add the 5w bulbs? I.e is the lamp holder and wiring there already or is it a completely different unit? I only ask as it'd look kindof neat to have both
you can just pull out the cap and fit a bulb and holder. The wire is not present in the headlamp plug though, so needs to be added. Not sure if the sidelight wire is in the main loom going into the plug anymore
Related Threads
Ford Automobiles Forum
2.3M posts
120.1K members
Since 2001
