Air bag light flashing 4 times
19 replies to this topic
#1 v6sierra
v6sierra
  • 65 posts
  • Vehicle Driven:Xr4i
  • Name:Geoff
Posted 28 April 2012 - 07:00 PM
Ok here goes, having bought the car the airbag light was flashing away I have looked on here and found the informative mirez site.
However after checking the wires under the seat the little annoying light is still there flashing away at me.
What else would be causing this problem, do I need to replace something????
#2 siruncle
  • Regional Moderator
  • 15,922 posts
  • 979 thanks
Posted 28 April 2012 - 10:41 PM
the light flashing 4x is for the seatbelt pre-tensioners and that's all, so its the seat bits that are the problem, you undid the yellow connectors under both front seats and plugged them back in a few times each, (can take a few times undoing, doing up to clear the fault) i presume?
the only other things it could be is a faulty pre-tensioner, (or its been fired), or the wiring between seat and airbag module.
2000 (W) Mondeo Mk2 Ghia 2.0 Hatch in Stardust Silver, now needing a pair of front jacking point covers... msg me
Thanked by 1 Member:
Exeter Mondeo Man
#3 v6sierra
v6sierra
  • 65 posts
  • Name:Geoff
Posted 29 April 2012 - 07:30 AM
Thanks, will try and have a look again today if this rain goes away, looks like I may have to get a couple of known to be good pre tensioners so I can eliminate them.
#4 EvoUK
EvoUK
    Big Buttie Megger
  • 892 posts
  • 19 thanks
  • Vehicle Driven:2000 Mondeo ST24
  • Name:Neil
Posted 01 May 2012 - 07:12 PM
You'll probably find as siruncle has posted by unplugging and plugging the connectors that will solves the problem. Maybe a bit of electrical contact cleaner spray would help too. Sometimes just moving the seat forward/backward, hoovering the carpets can jolt it enough to loose a full connection thus the flashing airbag light.
Mondeo ST24 Medium Steel Blue
#5 Funkydunks Mk2
Funkydunks Mk2
  • 71 posts
  • Vehicle Driven:98 MK2 Mondeo verona
Posted 04 May 2012 - 05:40 AM
Got the same problem. Looks like a dry day finally, so I'll give that a go this afternoon. Funny though mine only started flashing after i "tested" the handling on one of Basingstokes many roundabouts.
1998 Mondeo Verona. 1.8i Zetec silver top. Built: Feb 2nd 1998. 144000k. Probably needs an engine overhaul.
#6 Funkydunks Mk2
Funkydunks Mk2
  • 71 posts
Posted 04 May 2012 - 05:42 AM
#7 B1ggsy
B1ggsy
  • 307 posts
  • 9 thanks
  • Vehicle Driven:Mondeo MK3
  • Name:Biggsy
Posted 04 May 2012 - 06:55 AM
My Mk2 also does this, it is a common fault and i was told by my mechanic it is a sensor issue. He reset it several times each time lasting a few days to a few weeks. Dunno what the long term solution is, maybe replace the sensor or disconnect it?
#8 siruncle
  • 15,922 posts
  • 979 thanks
Posted 04 May 2012 - 05:54 PM
i chopped the plugs off and joined them up "permanently" with choccy blocks Like these, (well, same as): http://www.ebay.co.u...#ht_1192wt_1139
#9 Funkydunks Mk2
Funkydunks Mk2
  • 71 posts
Posted 05 May 2012 - 07:38 AM
Sounds like my sort of fix. Lol. Although if im going to make it permanent, I'll probably solder them together. My seat belt neefs renewing really. It struggles to reel back in. Would that cause a pre-tensioner warning? Would it be best to remove the seat when i solder them? The rails needs lubing anyway as its very stiff. Thanks. :-)
#10 siruncle
  • 15,922 posts
  • 979 thanks
Posted 05 May 2012 - 11:14 PM
you could remove them for better access to solder them and protect the carpet, and grease the rails whilst its out, DON'T move the forwards/backwards lever once the seat is loose as they are a :BEEP: to re-align. Pre-tensioner only works on the clip bit of the seat where the belt plugs into, what it does is pops a spring so the clip bit moves, yanking you back in the seat in a head on collision, all the wire does is check the circuit to fire it is working, if the connection is duff or the pre-tensioners fired, that'll make the light flash. Try pulling the belt out and using aerosol furniture polish (like pledge) iirc, on the bit you don't wrap round you (both sides) and a little down the hole where it goes, it might take a few days to work but should help it retract. :L
