Mondeo Estate Owners - I Need A Measurement Please!
7 replies to this topic
#1 lamlash
lamlash
  • 23 posts
  • 1 thanks
  • Vehicle Driven:Mondeo Estate
Posted 21 June 2012 - 07:29 PM
Hello,
I'm after a big favour from someone with a MK4 Mondeo Estate with factory fitted roof rails. I'm getting some roof rails retrofitted by a local bodyshop next week and they have asked for a measurement so they can ensure they position the rails correctly. I have sourced the rails from a breakers yard and bought new securing nuts from Ford so all I need now is tell them exactly where they fit. I expect that once the bodyshop has removed the headlining it will be obvious where the rails should fit and it will just be a question of drilling through the top skin of the roof in the right places but just in case it isn't obvious I could do with the measurement.
I have found a photo of a MK4 Mondeo Estate roof - any chance someone could go out with a tape measure (if it ever stops raining!) and post the measurement please (I've highlighted the measurement I need in the image below which shows the back of a MK4 estate with the tailgate open)
Thanks in advance. I'll post a picture of my car with and without the rails once the job is done.
#2 mwdurham
mwdurham
  • 5 posts
  • 1 thanks
  • Vehicle Driven:Mondeo Estate Mk4
Posted 26 June 2012 - 07:57 PM
I make it 22mm on mine using a tape measure
Do you know the details of hoe they are fitted. One of the front mountings on mine is loose and I don't know if I'll have to remove the headlining and tighten it from underneath. Is there a way to remove the covers without doing that?
Thanked by 1 Member:
lamlash
#3 malford
malford
    Titanium X Sport
  • Forum Moderator
  • 1,067 posts
  • 66 thanks
  • Vehicle Driven:Titanium X Sport
Posted 26 June 2012 - 08:18 PM
Headlining will need to be dropped in the corner affected...
http://www.talkford....ttach_id=124406
2013 Mondeo Titanium X Sport Wagon 2.2 PSA Turbo
Now on my 4th Mondeo...
#4 lamlash
lamlash
  • 23 posts
  • 1 thanks
Posted 29 June 2012 - 07:29 PM
Thanks mwDurham, Job's done and all seems to be OK. Before and after pictures hopefully attached.
#5 mwdurham
mwdurham
  • 5 posts
  • 1 thanks
Posted 30 June 2012 - 10:07 AM
Looks good! I will tackle my loose one this week. Looks like I have lost the battle with Ford to fix it - mine's just over a year old and apparently "trim and bodywork" is only covered by the first year warranty...
#6 mwdurham
mwdurham
  • 5 posts
  • 1 thanks
Posted 09 July 2012 - 10:37 AM
Sorted mine out now. For some reason the fixings were loose, once I dropped the headlining it was a simple tightening-up job with a 10mm socket from underneath.
#7 GWSFife
GWSFife
  • 1 posts
  • Vehicle Driven:Ford Mondeo
  • Name:Gavin Swinton
Posted 10 August 2012 - 04:27 PM
Hello,
I have been thinking of retro fitting roof rails to 09 estate. How big a job was it for the body shop, ie in and out in a day?
#8 lamlash
lamlash
  • 23 posts
  • 1 thanks
Posted 10 August 2012 - 09:24 PM
It was a 1 day job, although quite fiddly and involved removing lots of trims to get the headlining down. I'm really glad I didn't try it myself!
Good luck with finding some MK4 estate rails - I phoned a few breakers and eventually got lucky. My local Ford dealer couldn't even provide part numbers except for the securing nuts.
GWSFife
