F-Super Code Reader
15 replies to this topic
#1 paul-89
paul-89
  • 182 posts
Posted 28 June 2012 - 07:33 AM
My code reader arrived yesterday unfortunate the instructional video was in Chinese and was no help anyway I decided to give it ago, went out to the car after installing the software, it asked what com port to use, all except port 3 were in use, so I opted for port 3, it told me connect the reader to the laptop then to the car press ok, the select ecu as nothing popped up in the big white box I clicked on the boxes on the left hand side, I tryed all the boxes, and they all open and I get told no dtc's but the live data doesn't change any ideas?
#2 nicam49
nicam49
  • Gold Member
  • 721 posts
  • 41 thanks
  • Vehicle Driven:Mondeo mk3
  • Name:Nick
Posted 28 June 2012 - 08:12 AM
Hi, you've got to have your ignition switched on for it to read the ecu. Also, what year is your Mondy as the early ones may not work with f-super (depends if it's diesel or petrol, I think)
nicam49 2002 Mondeo TDCi Ghia X Estate mk3 pre facelift Stardust Silver+ Rust 239,000+ miles...fingers crossed! still running on 3 original injectors.
#3 paul-89
paul-89
  • 182 posts
Posted 28 June 2012 - 08:49 AM
When I plugged it in ignition was off then turned it the car on for live data, it's a 54plate 2.0 cdti 130 so it should work
#4 paul-89
paul-89
  • 182 posts
Posted 28 June 2012 - 08:59 AM
I used it the same way I used my old code reader, ignition off follow promps plug in2 the car ignition on turn car on for live data, I don't know if it's meant to be done differently, the car is a 54 plate tdci 130 so should be fine
#5 paul-89
paul-89
  • 182 posts
Posted 28 June 2012 - 09:01 AM
Sorry about the 2 messages my phone said it didn't upload the 1st
#6 paul-89
paul-89
  • 182 posts
Posted 28 June 2012 - 08:44 PM
Any ideas on what to do? Iv emailed the seller hopefully I will get new instructions
#7 PURPLE_2L_LX
PURPLE_2L_LX
    Mondeo Mk3 Moderator
  • 16,021 posts
  • 747 thanks
Posted 28 June 2012 - 10:01 PM
Did you install both sets of drivers?
In device manager you should have one under COM ports and one under USB, The
one under COM ports will have the port number.
Ive had anything from COM 1 to COM 14 on various devices.
2004 TDCi 130 LX Estate. (6)
#8 paul-89
paul-89
  • 182 posts
Posted 29 June 2012 - 05:13 AM
I installed everything on the disc, and after I tried to see if it worked and failed I just plugged it into the laptop again and let it download software from the net still no joy I'll have another play with it tonight cheers for the reply, if non of it works it's goin bk
#9 fmmarty
fmmarty
  • 114 posts
  • 3 thanks
Posted 29 June 2012 - 10:16 AM
I've had exactly the same with a generic device, both drivers install correctly and the software opens the port but then wont read dtcs .the led on the device shows blue and I have a usb to serial converter and a usb device in the control panel of the laptop . Confused.com !
R.I.P 2001 Y MK 3 zetec 1.8 petrol (write off, twice in 1 year !!)
1997 R MK 2 LX 1.8 petrol ( repairs on a daily basis !!! )
2001 Y MK3 2.0 Zetec petrol (currently giving it C.P.R!!)
No matter who you or i elect into power, remember ,we have the power , we're the leaders , dont let the goverment try to tell you what to do !!!
#10 paul-89
paul-89
  • 182 posts
Posted 29 June 2012 - 02:17 PM
Iv downloaded fordscan and formidable, there's nothing else on the disc accept an adobe file in Chinese and a video in Chinese the seller has said they would look into it, do chances are nothing's going to happen
