Turbo/intercooler Leak?
19 replies to this topic
#1 markleavesley
markleavesley
    TwoSpanner
  • 154 posts
  • Vehicle Driven:Mondeo
  • Name:Mark
Posted 08 October 2012 - 09:54 AM
Hello,
On a long drive yesterday I noticed that whenever I put my foot down there was a sound rather like a window or door not quite closed. It wasn't this because the sound went no matte what speed I was doing so long as I was cruising, and likewise no matter what speed I did when I put my foot down and the revs went above around 2250 it started. I had a quick look at the engine at a services and found there is a noticable waft of air coming up the side of the engine between the block and the air filter, I don't know exactly where from. If you rev it up a bit it's a strong air flow and it seems to be coming from the entire side of the engine though I find it hard to believe I can hear it inside with the radio on.
Having poured over this engine before and a prior Mk3 I can't say I've ever noticed this before, and it's be pretty hard to miss.
There is no obvious loss in performance though my MPG is slowly falling (I have a suspect oil cooler thermostat as well) or any new noises.
I haven't had chance to look with a torch to see exactly what is down that side of the engine but I guess the intercooler hose back to the air intake must be in that vicinity.
Any ideas what this might be?
#2 Rogerp1
Rogerp1
  • 2 posts
  • Vehicle Driven:Mondeo mk3 tdci
Posted 08 October 2012 - 12:05 PM
Sounds like a tear in your EGR hose to me.
Do you get lots of black smoke when you rev up?
#3 jakthelad
jakthelad
  • 15 posts
  • Vehicle Driven:Mondeo 2.0 tdci
  • Name:Stephen Butler
Posted 08 October 2012 - 04:21 PM
I had a similar problem and after checking all hoses found the turbo intercooler had a hole in it probably been hit with something. Replaced it and it now pulls like a train with no black smoke.
Hope this helps
#4 markleavesley
markleavesley
    TwoSpanner
  • 154 posts
  • Name:Mark
Posted 08 October 2012 - 04:23 PM
So far as I am aware the only smoke the car ever produces is a little puff when I first turn it over, but I will have a look tonight, easier to spot smoke in the dark when other drivers can light it up for you.
#5 markleavesley
markleavesley
    TwoSpanner
  • 154 posts
  • Name:Mark
Posted 08 October 2012 - 04:39 PM
Just had a look under the engine cover and couldn't see anything obvious. Started the engine and there it is, the breeze...which stopped as soon as the cooling fan stopped. I always thought the fan blew air through the radiator not into the engine bay? So maybe that is a red herring, maybe that is not the source of the noise whenever I accelerate.
#6 nilagin
nilagin
    ME
  • 5,135 posts
  • 82 thanks
  • Vehicle Driven:Mondeo ST TDCi
  • Name:Neil
Posted 08 October 2012 - 06:08 PM
The fan sucks air through the radiator so will blow the air into the engine bay. I'd certainly check all hoses.
Panther Black 2007 Mondeo ST TDCi. Eibach Pro-kit Lowering Springs - Forge Silicon Boost Hoses & Induction Pipe - EBCTurbo Groove Discs and Redstuff pads - Wingy Decat - K&N Panel Filter - Airtec Intercooler - MIJ Performance Stainless Steel Exhaust - AmD Custom Remap 190bhp, 326.5lb/ft Torque
Ford ETIS
http://www.etis.ford.com/vehicleRegSelector.do;jsessionid=848B1D74364B9315B7F32CE42E0F6FEE.fcvas512
#7 salta
salta
  • 5,267 posts
  • 346 thanks
Posted 08 October 2012 - 07:28 PM
yep the fan draws air back into the engine bay and is probably your source of air blown back there . and you would probalby hear it in the cabin if you were listinning out for it . but my worry would be why is the fan running so much . it it the a.c on all the time is the engine coolant ok. is the fan cowling noising . is the cht ok . .. the fan on these dosent run for long .. and hardly runs atall when the motor is being diven along mway. s
#8 markleavesley
markleavesley
    TwoSpanner
  • 154 posts
  • Name:Mark
Posted 08 October 2012 - 07:36 PM
It sounds for all the world like a window is open a crack and you're going down the motorway. Never heard it before and we certainly weren't listening out for new sounds! I'll see if it re-appears on my commute tomorrow though I have no idea how I'm going to locate it.
#9 markleavesley
markleavesley
    TwoSpanner
  • 154 posts
  • Name:Mark
Posted 09 October 2012 - 12:08 PM
The sound is extremely predictable. If I accelerate from say 20mph in 4th, the sound starts from 1500rpm and keeps going until I stop accelerating. If I drive at 20mph in 2nd there is no sound despite the high rpm. Same in 3rd and it starts around 2000/2250rpm.
Seems to be, and this is in laymans terms, the more stress I put the engine under to accelerate the earlier the sound starts.
If I red line it stationery you can't hear the sound, inside the cabin or with the bonnet open.
#10 markleavesley
markleavesley
    TwoSpanner
  • 154 posts
  • Name:Mark
Posted 14 October 2012 - 03:24 PM
Fixed, fault was exactly as described and located by using the sound and looking for oil (it was spattered everywhere). Patched with some tape until I can get a new pipe. Not really had chance to test it other than on local roads but the noise difference in the cabin is astounding, even when idle and it def. pulls/accelerates better.
Thanks everybody.
