\help Required For Code Reader
11 replies to this topic
#1 cyril
cyril
    Cyril
  • 60 posts
  • Vehicle Driven:2005 ghia x tdci
  • Name:Cyril Walklet
Posted 01 December 2012 - 01:00 PM
Hello folks
I have recently purchased a F- Super mk 2 code reader which has l6 pins.
My plug socket has 5 pins at the top and 6 at the bottom. Can anyone advise me which cable I should obtain to plug into my laptop to read codes. Mk3 TDCI 53 reg.
Thanks. Cyril
#2 Fluidthegreat
Fluidthegreat
  • 136 posts
  • 1 thanks
  • Vehicle Driven:mk1 focus 1.6
  • Name:Lewis
Posted 01 December 2012 - 03:40 PM
Has it not got a USB on the end
MONDEO 2.0L TDCI 2004 (euro4)
#3 cyril
cyril
    Cyril
  • 60 posts
Posted 01 December 2012 - 03:46 PM
Hi Fluidthegreat
Yes, the cable has a usb at one end but the other end does not seem to be compatable with the socket on the car.
Thanks.
Cyril
#4 salta
salta
  • 5,479 posts
  • 362 thanks
Posted 01 December 2012 - 06:04 PM
the reader i have does not have that problem but I suggest you plug the lead in or attempt to .. as there are probably spare pins on the plug. the plugs are a standard shape and have a standard amount of pins in the socket and standard amount of receiptor pins in the plug . also the shape of the plug is similar to the shape of the socket in your motor . soo plug it in and see if it adapts . it is sold for the intended connection so plug and play . s
#5 cyril
cyril
    Cyril
  • 60 posts
Posted 01 December 2012 - 07:11 PM
Hi Salta,
Thanks for your reply to my query.
The plug and socket are the same shape and I did try to connect them but as they were so tight I thought that I had the wrong cable. I didn't want to force it in case I caused damage. I will have another go tomorrow.
Thanks again,
Regards, Cyril
#6 Fluidthegreat
Fluidthegreat
  • 136 posts
  • 1 thanks
  • Name:Lewis
Posted 01 December 2012 - 07:38 PM
i just put mine staight to the car. it is a tight fit but mine is fine
#7 PURPLE_2L_LX
PURPLE_2L_LX
    Mondeo Mk3 Moderator
  • 16,285 posts
  • 763 thanks
Posted 01 December 2012 - 07:59 PM
I always support the socket on the car from behind when plugging it in.
A firm push is all thats needed. Dont fit it upside down :)
2004 TDCi 130 LX Estate. (6)
#8 cyril
cyril
    Cyril
  • 60 posts
Posted 01 December 2012 - 08:06 PM
Hi Purple 2l lX
I did support the fitting and it was the right way up. Will try again tomorrow.
Cyril.
#9 cyril
cyril
    Cyril
  • 60 posts
Posted 03 December 2012 - 11:43 AM
Hello Folks.
I have now connected the F-Super lean to the car - very tight fit-- and installed the CD and have live data on my laptop.
My Egr is blanked off and of course the eml light is illuminated. Should a fault code show up for this. No DTCs are detected according to the data. Also should there be three lights illuminated on the F-Super interface. Mine seems to have two lights on.
Any help would be appreciated.
Thanks.
#10 PURPLE_2L_LX
PURPLE_2L_LX
  • 16,285 posts
  • 763 thanks
Posted 04 December 2012 - 11:09 PM
If the engine light is on you should have a fault code stored.
Its not a euro 4 car is it? If not then blocking the should not cause the engine light.
Check the ETIS link below and see what emissions your car has. Stage 4 = euro 4
EEC 7 = euro 3.
One light is the data transfer. Can you see live data? Revs and fuel pressure etc.
