Replacing Door Speakers
13 replies to this topic
#1 Jon_F2003
Jon_F2003
  • 6 posts
Posted 16 June 2003 - 04:33 AM
I have just fitted a JVC3101 into to replace the Ford6000 stereo, now I have the better quality sound I want to replace the rear speakers as they have obviously had better days as the crackle if I use them.
Is this a big job as I was quoted £30 a speaker to be fitted, and I could probably do it myself.
Should I attempt it??
Incidentally I was told that the standard Ford speakers are only 25w each is this right??? The stereo recomends at least 75w per speaker so should I replace the front as well???
#2 Manix
Manix
    being SUPRISED! (maybe)
  • 4,346 posts
Posted 16 June 2003 - 04:45 AM
Ive just fitted some in the front and it was a POP apart from some drilling to match up the holes, back is the same from what ive seen........
1996 Mitsubishi Lancer Evo IV
2006 Ford Focus 2.0 Ghia SALOON
(seen one yet? have you?)
2000 Mondeo Ghia X Estate
French section...
1997 Citroen Xantia VSX hydractive
1997 Peugeot 406 thing
#3 troh
troh
    Advanced Member
  • 46 posts
Posted 16 June 2003 - 12:22 PM
To change speakers is not that hard thing to do. Try yourself first and if no success...
But, front speakers are the most important parts of the sound system in your car. So why to change rear speakers first? How about if you change front speakers to decent 6.5" component system and leave rear speakers as they are. Or have you already done this?
#4 troh
troh
    Advanced Member
  • 46 posts
Posted 16 June 2003 - 12:26 PM
This don't matter, since you wont get over 25W from head unit amplifier. But as I already stated, I recomment to buy a component system to front and live with originals at back.
#5 Oz
Oz
    Administrator
  • Administrators
  • 19,522 posts
  • 10 thanks
Posted 16 June 2003 - 02:04 PM
Change the fronts to better stuff and then put the front speakers into the back. If you check out the member services section you'll find my how-to. It's as easy as it looks, really! :)
Edit - cos I'm nice, here's the direct link:
http://www.fordmonde...ds_speakers.htm
Ford Focus ST170 with Comfort Pack, factory boot tip spoiler, lowering springs, steel braided brake hoses, clear LED rear light clusters, clear rear fog lamp, pillar pod and digital gauge
#6 Nathan
Nathan
  • 82 posts
Posted 16 June 2003 - 04:42 PM
I followed Oz's guide and replaced all four speakers this weekend - took me around 1.5 hours (spent time giving the various bits of the door a good clean as well!)
Cheers for the How-to! :) Very easy to do.
#7 Oz
Oz
    Administrator
  • Administrators
  • 19,522 posts
  • 10 thanks
Posted 16 June 2003 - 04:58 PM
Glad I could help ::
I was daunted first time cos I didn't want to break anything but having done it the first time, it gets much easier - I can now have the door apart in no time at all
#8 Too_Fast
Too_Fast
  • 10 posts
Posted 16 June 2003 - 09:12 PM
£30 per speaker?!?! :o :o
Do it yourself mate....it's a doodle!
#9 Jon_F2003
Jon_F2003
  • 6 posts
Posted 17 June 2003 - 12:07 AM
cheers guys, once I got my kit fitted, that'l be my next job. Read through the guid and it does sound easy enough to do. :)
The Mondeous
1997 LX 1.8 -
Full StreetFighter Body Kit
BK299 17"
Morette Headlamp conversion
Lowered 40mm
JVC MP3 K3101 50W PICT CD CHANGER
#10 bazweller
bazweller
  • 199 posts
Posted 17 June 2003 - 01:36 AM
i can remove a door card now in under 2 mins. not that i keep changing my mind on what speakers to use ::
baz
baz1977@hotmail.com
come and hassle me on msn
