Recent Topics
MK3 Heater blows cold when hot selected (any ideas guys)
27 replies to this topic
#1 mrk2
mrk2
  • 658 posts
Posted 08 January 2007 - 11:46 AM
Hi Guys
Yesterday went out for a blast in the 220, selected heaters once engine was warm and all it did was blow cold with the heater selected hot.
Stopped turned the eng off waited restarted teh engine and it was all working fine again
Tried it today and again no problem
Has anybody else had this or has anybody got any info on this problem
Cheers  :L
#2 Dansmondeo
Dansmondeo
    Just me
  • Lifetime Gold Member
  • 19,670 posts
  • 2 thanks
Posted 08 January 2007 - 09:00 PM
Dont know, but mine was not blowing any hot air today either  :annoyed:
BMW 523i Touring - 2.5, straight 6
Understeer is when you hit the wall with the front of the car.
Oversteer is when you hit the wall with the back of the car.
Horsepower is how fast you hit the wall and torque is how far you send the wall across the field once you've hit it.
Past Mondeos - 2001 MK3 TDDi Ghia Estate, 2000 MK2 2.0 Zetec, 2000 MK2 1.8 TD, 1997 ST24, 1995 MK1 2.0 GLX
#3 mrk2
mrk2
  • 658 posts
Posted 09 January 2007 - 04:16 PM
Stange
My car is going into ford tommorow so will ask them and post up
Is yours a MK3
#4 mrk2
mrk2
  • 658 posts
Posted 10 January 2007 - 04:15 PM
According to Ford dealer all sorted now after Aircon reprogramme
We will see  :shifty:
#5 pipster
pipster
  • 106 posts
Posted 10 January 2007 - 04:26 PM
This sounds like a similar problem my Mrs had with her Fiesta.  There is a kind of valve (name escapes me at the moment) which moves when you turn the heater dial.  It mixes the air from outside to the heat coming from the engine.
It sounds like the valve has got stuck in the cold  (air from outside position)
It had to go into Fords and didn't take very long to fix.
2003 (53) Stardust Silver Mondeo Zetec 2.0
See my car in the garage
Are we all we seem? Find out at www.thurrockparanormalforum.com
#6 jungleistmassiv
jungleistmassiv
  • 281 posts
  • 1 thanks
Posted 18 January 2007 - 12:14 PM
my mk3 does it too sometimes, put it to hot, and it blows freezing air for about 10 minutes, then suddenly blows hot!!!
#7 Laki
Laki
  • 36 posts
Posted 18 January 2007 - 04:11 PM
That’s right. If you ask me this is the most common problem with mondeo. I read about it on many places on the web, I have exactly  the same problem and my friend has it too, unfortunately I couldn’t find the reason for this problem and this is very strange because it is so common but nobody knows what is wrong with it.
So does anyone knows what needs to be fixed, changed or whatever to cure this, this is so irritating.
I’m sorry English is not my mother language so I probably made a lot off grammar errors.
Regards!
#8 nicknack
nicknack
  • 621 posts
Posted 22 January 2007 - 12:49 PM
I had this with the EATC in my MK3.
Firstly I cleaned all the dust and crud from the interior air temperature sensor (behind the little vents on the cowling below the steering wheel.
Secondly I replaced the sensor.
Thirdly I set the EATC to manual and all seems fine!
#9 scotty16
scotty16
  • 106 posts
Posted 28 February 2007 - 10:44 AM
This is from this site I found yesterday, seems to be relevant to only one year but I hope it helps :-
http://www.bba-reman...s_and_solutions
Ford Mondeo 2002
Problem: Only cold air from heater even on hot setting.
Solution: This year Mondeo is known to suffer from a sticking temperature flap in the heater housing. The solution is to use a torx T50 and free the temperature flap.
Mk3 2004 2Ltr TDCI LX Estate
#10 Dansmondeo
Dansmondeo
    Just me
  • 19,670 posts
  • 2 thanks
Posted 28 February 2007 - 12:29 PM
This was really bugging the hell out me yesterday. I leave mine on auto all the time, driving down the motorway in a t-shirt and temp at 22, then it starts blowing cold air! I have to put it up to Hi to fix it.
Does anyone know what the temperature flap looks like or how to get to it?
#11 compuwiz_uk
compuwiz_uk
  • 17,223 posts
  • 244 thanks
Posted 28 February 2007 - 08:13 PM
Here's what the disc were not supposed to have says about it  :L  ( also stuck in a couple of piccies for the sections 8 & 9 ( remove if it breaks any site rules etc )
Left-hand drive vehicles
µ 1. Detach the damper from the glove compartment.
1 Open the glove compartment.
2 Push the top of the damper away from the glove compartment.
µ 2. Fully open the glove compartment.
Press the sides towards the centre to release the glove compartment.
µ 3. Remove the glove compartment.
Release the hinges.
Right-hand drive vehicles
µ 4. Remove the driver side lower footwell trim (three clips).
µ 5. Remove the instrument panel lower panel.
1 Remove the retaining bolts.
2 Release the retaining clips.
All vehicles
6. Start the engine and operate the A/C system for 10 minutes with the following settings:
l A/C button on,
l temperature setting to fully cold,
l blower position 1,
l air distribution to the footwell.
7. Switch off the engine.
µ 8. Remove the temperature flap positioning motor.
l Disconnect the electrical connector.
l Remove three Torx bolts.
µ 9. Use a Torx T50 socket wrench to free the sticking temperature flap.
l Insert the Torx T50 socket wrench into the mounting for the positioning motor and turn the temperature flap to the left-hand stop until the flap moves freely.
l Then turn the flap to the right-hand stop using a maximum torque of 3 Nm to the stop.
l Then turn the flap to the left-hand stop until it moves freely again.
l Repeat the process to loosen the temperature flap 10 times.
µ 10. Install the temperature flap actuator motor.
l Install three Torx bolts.
l Connect the electrical connector.
11. To install, reverse the removal procedure.
Initialise the A/C system.
12. Initialise the A/C system.
Note:
Switch off the ignition.
l Remove fuse F65 from the central junction box (CJB) for at least 20 seconds.
l Install fuse F65.
l Switch on the ignition. The A/C system initialises itself automatically within one minute.
13. Check the operation of the A/C system.
#12 Strawbs
Strawbs
  • 145 posts
Posted 07 March 2007 - 06:05 PM
I've suffered the same symptoms before! once it would only blow hot, the other cool! on both occasions a Climate reset was all that was needed!
How to do that is posted here somewhere.
Edit:
Breifly press both the "Off" & "Footwell" buttons & release, Press "Auto" button & release!
the system will run a self diagnostic - testing all segments of the display & Flap motors! Once the motors fall silent & display freezes! Press the "Defrost" button to reset the system, delete error codes from memory & exit diag mode! wait til the system again falls silent before running up to temperature & testing system. All of this takes around a minute to complete.
thanks to Istvan
original post here!
#13 Dansmondeo
Dansmondeo
    Just me
  • 19,670 posts
  • 2 thanks
Posted 14 March 2007 - 03:50 PM
Thanks guys, I will try a reset first :L
#14 rainbowcar
rainbowcar
    Glen
  • 4,110 posts
  • 9 thanks
Posted 22 March 2007 - 12:11 AM
:offtopic: disc? what disc?
Panther Black Mk3 TDDi Ghia X - Cream Leather!
Metropolis Blue Mk3 TDDi LX.  - Gone but not forgotten.
#15 compuwiz_uk
compuwiz_uk
  • 17,223 posts
  • 244 thanks
Posted 22 March 2007 - 12:48 AM
Quote
ford TIS disc.
#16 Dansmondeo
Dansmondeo
    Just me
  • 19,670 posts
  • 2 thanks
Posted 26 March 2007 - 06:59 AM
So far so good with the reset :L
#17 nicknack
nicknack
  • 621 posts
Posted 18 April 2007 - 12:03 PM
Quote
Release the hinges.
All vehicles
l A/C button on,
Note:
l Install fuse F65.
Tried this at the weekend as still having problems with mine...
The flap wasn't stuck, so I tried a reset and hopefully this will sort it as there's no error codes showing up on the panel.
Doing a long journey at the weekend, so we'll see what happens (probably freeze then boil, freeze then boil, etc.).
Nick
#18 EssexJohn
EssexJohn
  • 28 posts
Posted 25 November 2007 - 04:52 PM
i just tried this and still is cold.
where can i get a new motor from? could not see any on ebay.
thanks
#19 cwaiton
cwaiton
    Newbie
  • 3 posts
Posted 27 November 2007 - 11:59 AM
Have you tried swapping motors on the heater box .There are three motors that are all the same. If you swap the bottom two over ( bottom one is the blend motor that mixes hot and cold air) with the one directly above it, this will prove if it is the motor at fault or not.
Before doing a reset on the system by removing fuse F65 make sure you have run the system with settings recommended above as the system will reset to fully cold when you put the fuse back in and everything has to be in that position for it to work correctly.
#20 EssexJohn
EssexJohn
  • 28 posts
Posted 27 November 2007 - 08:14 PM
i didn't notice they were the same motors, ill give it a go sunday.
out of interest, what does the top motor control?
