P132B fault code
5 replies to this topic
#1 Adi69
Adi69
  • 1,614 posts
  • 1 thanks
Posted 06 August 2007 - 11:50 AM
Hi,
Following the engine management light coming on the other day, I had the car checked for fault codes.
P132B....with no other letters was one that came up. Has anyone come across this before?
#2 rasman81
rasman81
  • 243 posts
Posted 06 August 2007 - 04:16 PM
I thought that 132 was an o2 sensor high voltage, but the diesel does not have o2 sensors as far as i'm aware.
Kevin
2004 Ghia X Estate
Previously, ST24 Hatch, ST200 Estate
#3 ScoobyChris
ScoobyChris
  • 1,207 posts
Posted 06 August 2007 - 06:34 PM
I did a Google and turned up this excellent site: http://www.fordtechs...-releaseHL1.pdf
which seems to suggest a possible sticking turbo....
Question:
What is the new P132B code?
Answer:
P132B is a new P-code that was added to monitor turbocharger performance. There are 3 new PIDs
that indicate what operating mode the code was set in, these are:
⇒ P132B_STK sets during the learn mode
o Verify that the turbocharger learn has successfully completed VGTVP_LE > 5 and
VGTVP_OK = yes and check the learned values to make sure that they are within a
correct range
o Run through the normal KA test to verify the turbocharger is actually sticking
⇒ P132B_CM is a continuous monitor
correct range
⇒ P132B_VAR sets if the turbocharger does not converge
All turbochargers must be tested through the KA test to verify improper operation.
Chris
Colorado Red '02 Mk3 Ghia-X TDCi (130bhp) - ummmm standard-ish ;)
#4 Adi69
Adi69
  • 1,614 posts
  • 1 thanks
Posted 06 August 2007 - 06:55 PM
Thanks for looking Chris.
I too did a Google and found:
http://www.fordinsta...hatsnew/DTL.pdf
If you look at pages 16-19, then along with code P600A which was there too....it shows all the possibilites.
The EGR has been fully cleaned out using a sonic cleaner, it is now fully closing, which is wasn't before. The memory has been cleared and I'll have to see if it returns.
#5 look8one
look8one
  • 8 posts
Posted 16 February 2009 - 04:43 AM
clean the MAF sensor with Electrical solvent cleaner (maplin) Be carefull with two termistors they are easy to damage. It helped me and cost only 4 quid! yes! reg
04reg Zetec S 130bhp 6speed PLATINUM
#6 Adi69
Adi69
  • 1,614 posts
  • 1 thanks
Posted 16 February 2009 - 01:48 PM
Well done for sorting yours matey. My car was constantly coming up with P123B which is turbo performance and when manually operating the turbo vanes, they were indeed sticking. I also watched the vanes stick one day when turning off the engine.
I have previously cleaned the MAF as well
