HEATER CONTROL KNOB 'SPONGY' , HEATER NOT WORKING
7 replies to this topic
#1 NESSA
NESSA
  • 10 posts
Posted 18 October 2007 - 06:44 PM
HI ALL,
my heater control knob has become spongy/springy i.e you turn it one way and it has opposite resistance. AND the bloody heater does not work at all.V colD!!!
please help guys
ness
#2 stevedohc16v
stevedohc16v
    MEG Commander
  • Forum Moderator
  • 5,015 posts
  • 66 thanks
  • Vehicle Driven:Many Fords!
Posted 20 October 2007 - 08:00 PM
Do you mean the temperature control knob? Usual problem is that the temp control lever has started to seize up and the cable that tries to control it kinks and wont move the lever so the kinked cable forces the knob back round, cure is to renew the cable and/or free off the temperature control lever.
Steve
Current Mondeos are:
53 Ink Blue ST220 estate
97 Panther black 2.5 ghia X saloon
And my other toys are:
1994 Ford Escort RS2000 4x4
1987 Ford Capri 2.8i special
1998 Ford KA2 & 1998 KA3
#3 NESSA
NESSA
  • 10 posts
Posted 21 October 2007 - 02:22 PM
thanks i will have a look ata that x
#4 NESSA
NESSA
  • 10 posts
Posted 21 October 2007 - 04:47 PM
you were right!how do you change the heater cable?
#5 roofie71
roofie71
    Newbie
  • 1 posts
Posted 21 October 2007 - 06:22 PM
My Heaters also blowing cold air.......Brrrrr!!!!
Sounds identical problem to mine, I'd read somewhere that the control 'flaps' got stuck, unfortunately I have no idea where these are and how to get to them. I've tried removing my heater control panel today, nightmare, I'm a bit lost as how to get to everything, girls......!!!!!
#6 stevedohc16v
stevedohc16v
    MEG Commander
  • Forum Moderator
  • 5,015 posts
  • 66 thanks
Posted 23 October 2007 - 06:20 AM
Quote
The cable isnt the root of the problem its the control lever up in the drivers side footwell, reach up on the centre console side and you will feel the cable going to the lever, give the lever a good spray with wd40 and work it back and forward, if this does no good then its siezed internally and theres not much you can do other than fit a new cable and operate the temperatre dial very slowlt to 'coax' the lever to move, if you try and force it too much you will just kink it again.
Steve
#7 NESSA
NESSA
  • 10 posts
Posted 23 October 2007 - 04:38 PM
cheers i did try this but the cable seems to dissapear behind the heater matrix(?) and seems inaccessable. Will have another look!
ness :ponder:
#8 hezzie
hezzie
  • 9 posts
Posted 05 July 2009 - 05:45 PM
Brilliant, Haynes manual was just about to get me to remove the radio, heater controls etc but I read this and found the problem is exactly as described above, thanks for saving me a load of hassle, I'll order a new cable before I remove the control panel then do the whole job at once.
Cheers Steve :thumbup:
