1 - 7 of 7 Posts
hi ppl great site am newbie :banana:
i have 2013 focus 1.6 tdci econetic
problem is engine shakes when turn off plus have eml light on with code po2e4 which is diesel intake valve stuck open car runs fine otherwise
so things i have looked in to are and i have done cleaned egr valve maf thottle body all pipes which connect them all
also changed vacuum valve on front engine black box 3 pipes on
last thing i can delete code but it comes back after bout 3/4 times turn engine off
Hi there I have exactly the same problem, same car...I’ve tried 2 2nd hand Delphi throttle bodies which are £450 new and no joy...can’t find any broken wires and potentiometer give correct readings so doesn’t point to the PCM...I’m lost did you have any joy
Did you have any luck solving this problem? I have exactly the same...the thing is now strict MOT rules says it's a fail if engine management light on...it's a good car other than this any advice would be greatly appreciated.
Thank you
Hello I have been reading the Previous threads
I have an issue with a code PO2E4 Is causing for my DPF not to regenerate i have changed the throttle body and the mass flow sensor but had no luck ..I had a full DPF clean but its blocked again due to this issue...any help with this will be much appreciated.
Soot loadings exceeded maximum level? Try resetting the values to zero with a hot engine and take it
for a drive and monitor the soot loadings.
OBDII reader and Forscan software
1 - 7 of 7 Posts
