hi i am hoping you guys can help me, so had a mechanic look at my car because i new it needed front discs and pads,which he done, my next problem i suspected it needed a front wheel bearing which he said it does but he couldnt do it because he said there are wires going to it ,i said is the wires not for the ABS he said it would need to go to ford, next thing i asked if he would change the thermostat because my heaters dont seem to get hot anymore and the needle goes to half way when standing still but drops off when you drive and pick up a decent speed, he says its a wiring fault, now i am no machanic but i think hes wrong but maybe you guys can shine sum light, cheers shaun.
Wheel bearing don't need to touch abs sensor? So aload rubbish there and as for thermastat couple bolts a pipe and bobs your uncle walk away from this prat sounds like e. Nose nothing
Same as changing the bearing on most cars. One thing to watch is make sure the bearings
fitted the right way around. Black ring to the pickup.
