From memory it does look the same, three pin connector, with a tab to engage. Requires the tab lifting to open the mechanical-latch to split the male and female ends.
BEWARE - it is underneath the rail and although you can get to it relatively easily, the tab is on the rear and so you cannot open it by hand.
I ended up putting a tie wrap around it, pulling the tie-wrap against the body and then sliding the tie wrap down to effectively slide underneath the tab. Thus lift the tab relative to the connector body thereby opening the mechanical-latch.
If you have a spare one knocking about I would try it on that first so you understand how the latch operates.
Its really easy if you know what you're doing and how the tab works, but I certainly coudl not open mine using my fingers as they were too big, didn't hing 360 at every joint and I couldn't see the tab.
Harvey
Harvey
