hi i'm in the middle of starting a head gasket on a 2.0 zetec mondeo i've got the tool to lock the cams and thats about as far as i've got is there a link anywhere that can guide me through this as i've got a manual on the way from ebay but the blokes taking his time sending it p***k
any help will be appreciated
MEG Commander
If the manual from Ebay is the one i'm thinking of then it's the best guide to doing the job, just follow it step by step, apart from the cam locking tool the only other special tools you need is a decent set of 1/2" drive torx bits, be warned tho if you are replacing a head gasket thats blown due to overheating - zetecs have a tendency to warp the head and in extreme cases wipe the piston compression rings out as well, you might change the gasket and still have no compression.
Steve
