My Dad's 2005 1.6Ti-VCT Ghia has developed a problem with either the clutch or gearbox.
The story is that he went to change gear and lost all drive. There might have been a noise but he's not sure 🙄. The clutch is worn (bite point was really high before this happened).
These are the symptoms.
I've done a search for a replacement but do all 2005 1.6 focuses use the same 5sp box or could they be different?
Any advice would be really appreciated.
- With the engine running, you can't put it in gear without depressing the clutch (as you'd expect).
- There's a slight whine in neutral which has also been there for a long time before this happened, which disappears when you press the clutch.
- When you press the clutch, select a gear and lift off the clutch there is a very small amount of drive. Not enough to move the car but you can feel it.
