1 - 2 of 2 Posts
The reading on the text display consistently shows 7+ degrees over the air temp. If I knew its location, I might find an obstruction. Causing the misreading. I have also looked for a way to recalibrate the sensor too. Any other helps to get rid of this annoyance would be appreciated.
have a look behind the grille by the left headlight (left when sat in the car) it might only be visible from above, or below and you might need to remove some trim etc to see it. It should be behind the grille as shown in pic below.
1 - 2 of 2 Posts
