Hi,
My 2011 MCA (SD version with reverse camera), is getting stuck on the navigation startup stage. The little box comes up but doesn't go away & it just sits there. All other radio functions work ok.
If you go into the test menu then it is correctly reporting the GPS position, but pressing the info button doesn't show the GPS info.
Any ideas?
Thanks - Rob
If you press "Map" instead of "Nav" do you get the same welcome screen that you have to press ok to.
I am assuming that is what it sticks on?
Its the starting navigation box that comes up & then goes off again. I tried it again just now & it was fine! DOH .....
Never noticed that screen
I put the radio on
Press map and get the screen about distractions you have to press ok to
Then drive with the map in view as a default
When i press Nav i get the input destination screen.
Sounds like your Nav SD Card is going to fail. Did you change it recently to some other card?
