Been offered some 205/45 r16 wheels and tyres ,Will they fit as I have only seen up to 195/45 will fit .Anyone tried this wide thanks
Offered wheels from what?
205/45 Will be a good 10mm taller than the 195, If its a wider wheel or a different
offset then they may foul the suspension or stick out too far and contact the arches.
Yeah its a Fiat 500 under the skin with a different body and suspension setup.
Ford improved the suspension for the KA.
Were the wheels from the Standard 500 not one the 57 other variations?
57 Other cars that are a Fiat %00 or 500L or 500X or.... :)
If you do fit them make sure they clear the suspension and arches, also think about what
happens when you hit a bump. Will the clearance reduce?
Also your speed will underread, you will be travelling faster than it shows. (not a big amount).
