1 - 2 of 2 Posts
What rims can I put on my stock hight ranger 4cyl 4x4. It can be from other trucks or cars I just like to see if anyone has tried or know what I could use.
Also side question if I do 3in block lift do I need to do anything other then install them and drive off?
Here's a list of cars with the same pcd as a ford ranger, (5x114), http://www.wheel-size.com/pcd/5x114.3/
I can't guarantee they will all fit, but some may be compatible.
If you want to fit other wheels, you will need hub adapter/spacers
If you do the block lift, just check the propshaft has enough tolerance in the sliding joint to make up for any extra difference the block lift will make.
1 - 2 of 2 Posts
