1 - 7 of 7 Posts
:( hi all i ave got a td 1.8 on a m plate now my problem is that 1st thing its a nightmare to start i turn the key 4 times and wait for the little click from the engine every time,then i will turn the engine over till it starts which i have to keep the key turned to its fullest after 25-30 secs the revs build up enough to run!!!! :headshake: once the car has been run for 5 mins shes ok what could this be?? pls help
TDDI Buff
when was last service? oil, glow plugs, air filter?
the oil was done at the same time as my cam belt (which by the way took your advise returned to the garage and found that it was 1 tooth out nice full refund given and thay fixed free lovely jubbly thank you for that)i put a new air filter in 5 weeks ago do you think that it maybe the battery?
are you saying that the engine won,t turn over at normal starting speed to fire up?
my mother had this on a corsa turned out to be a damaged starter ring on the flywheel which meant that the starter had real trouble turning over
Could be as simple as duff glow plugs. If you can run a decent size extension cable out to your car do so and put a blower heater on it, protected by an RCD device, direct the blower into the air inlet and try and start. If it starts first time from cold its probably the glow plugs.
If it doesn't it could be the cold start wax stat thingy, its like an automatic choke for diesels, connected to the fuel pump via a bowden cable, the wax element sits under the battery tray.
If the heater thing doesnt work follow the cable from the wax stat thingy to the fuel pump and locate the little arm it operates, gently move that arm over as far as it will go against the spring without breaking anything and try and start, if it starts from cold its probably the xaw element thingy thats broke.
When mine went funny I sprayed the wax stat with WD40 and tapped it with a smallish hammer, worked ok for another three years.
It could be a million other things but the above are worth a go.
TDDI Buff
get a multimeter £5 in argos if you havent got one start the engine put it on the battery should show 14.4v or very close to it. If it is then battery is ok but if its higher its over charging and if lower its undercharging.
My name is Steve
er in doors escort "did" that now its sat in a workshop with the sympton of no compression and a knackered engine.
i,d check glo plugs and battery and the easy things first.
1 - 7 of 7 Posts
