So my 2012 Mk3 Focus flagged up a fault "Tyre Pressure Sys Fault - Service Required" and nicely lit up the ABS, traction control, and hill-assist lights yellow on the dash.
Got home, plugged in the elm and ForScan tells me its the rear right wheel:
(The other two code of C003A are "mechanical fault" and "incorrect sensor" but I suspect the "short to ground" is causing these)
Its intermittent, since it will clear itself from the dash (and then reappear at some point later) and similarly if you clear the DTC it will come back eventually.
Looking in the Helm Shop Manual it indicates to do point test 7 and refers to C440-1 and C440-2:
I'm assuming this is a connector - but does anyone have any hints on how I go about locating this connector? The ident is great, but it doesn't mean anything to me in terms of location etc.
Either that or any hints on where to look if this is a known issue of wear or chaffing on these wires?
Thanks in advance!
Thanks in advance!
