Hi, when I 1st start the car on a morning, it feels like the accelerator pedal is stuck. Any ideas why? Is it anything serious? Thanks
could be a dry or sticking cable, check its routing (especially if you've been working on the car) and check its on the throttle linkage properly, if you wanted you could remove the cable (in the engine bay) and spray some lubricant (wd40/plus gas etc) down it, failing that it might want replacing.
you can do this yourself, the cable pops off, should be pretty easy
