There koni adjustables but will only effect the damping. they are old units so maybe some coil overs would be a good upgrade as these can be used to manually raise or lower the car. other than that look into the old citreon bx air suspension setup. i was qouted around 2k for individual airbag suspension on the net then you just have to swap the legs over and connect it all up.
