I've just bought a Fiesta mk7.5 on a 63 plate. Whenever I put the air con on it activates the radiator fan and it doesn't stop spinning until I turn the air con off again, makes a right noise as well! It's a 1.0l ecoboost, has anyone else had this, is it just a characteristic of this engine or could there be something wrong somewhere? 馃
Yes the AC creates heat and there is a condenser in front of the engine radiator that needs cold air.
Normal for the fan to be on. Whether its on too fast or noisy due to a fault you need to investigate.
AC low so its working harder to do its job or a pressure valve is faulty or maybe that side is OK
and its a faulty fan?
Thank you for your reply, will get the gas checked first and take it from there. Good to know the fan will be on though. 馃憤
