Airbag 4 flash code.
578 Views 4 Replies 3 Participants Last post by  Flash635
I'm getting the 4 flash code on my airbag light, according to the wiki it means this:-
"Safety belt buckle pretensioner(s) failure. Short to battery plus or ground in safety belt buckle pretensioner circuit(s)"
I'm new to Mondeos and haven't worked on a pre tensioner, how do I fix this?
It's a 1997 Wagon.
You will need a known good, unfired pretensioner (or seat belt buckle) from a scarp car and swap it over and see if that fixes it.
Thanks, I'll look at that.
check the wires under the seat first,make sure they're firmly plugged in :L
I unplugged then replugged the yellow connector under the seat, that did the trick.
Thanks.
