now, usually when people say airbag light, its usually the yellow connectors under the front seats need unplugging and plugging back in again, especially if the seat has been moved or there was a load of stuff under it.
if that doesn't cure it, its usually the clockspring. Did you "reset" it to central before fitting it? (so it turns an equal amount of times in each direction before it stops?)
