Airbag light
579 Views 3 Replies 2 Participants Last post by  52graphite
Hi All,
Apologies if this question has came up before , hoping for some help.
When i switch on, airbag light flashes 4 times then twice .
Does that about 3 times then it stays on permanantly. Can anyone advise a cure please....
Many thanks in advance. :(
Crash sensor up by the bonnet latch.
Previously covered here:
http://fordmondeo.org/forum/showtopic.php?tid/829963/
Airbag flash code reference here:
http://fordwiki.co.uk/index.php/Airbag_Flash_Codes
Many thanks for that my friend :thankyousign:
Can you tell me how to rectify this fault please :confused:
Depends what the problem is. I'd start by locating the sensor (brown unit near the latch, IIRC) and checking the connection to it. If that all looked OK, I'd try replacing the sensor.
Do you have a Haynes manual? You'll want the facelift one for an '05.
