when the auto aircon is switched on the engine cooling fan kicks in and runs constantly, which is causing the engine to be over cooled and the heating never warms up.turn air con off the fan stops and the engine warms up normally.any ideas on why this
checked thermostat ,everything seems to be working fine.but i unplugged cooling fan to see if it made a difference.its made a huge difference,temperature fine now ,air con working perfect but its not solved my problem.should cooling fan run constantly with air con on or just when required??
