That adaptor only works for face lift models, if you have a pre face lift like me, you have to do some very careful cutting.
My Sony 7" touchscreen only just fits in my dash with its surround fitted, I had to carefully cut all the way to where the panels gloss finish starts at the top and bottom and had to go to within 1cm on the sides!
To make things even harder, during the cutting process, you cut away almost all the material that would normally support the head unit and I had to use absolutely all of the cage bend tabs and they had to be bent real hard up against the back of the facial plastic to get enough support.
I prefer my dash over the face lift but boy was it a mission going from a single din to a double din!
