i have the same problem, just gone and bought two new tyres to see if it would cure it. and its still bloody there, i'm thinking wheel bearing
It is defo your tyres, as they start to ware they will feather on the inside edge and it gives off a sound like your bearing is going, i had dunlops sports and if you ran your hand along the inside edge you could feel it. when i changed them the noise has gone.poppy6780 said:That's a coincidence , i've got the pirelli p6's on the back too , I've just bought different ones for the front & the noise seems quieter . I'm guessing it could be the blasted tyres then , I bought cheaper ones this time because pirellis are too expensive . £260 for 2 . I think not . I got some really meaty mid range ones for half that & they dont hum going down the road !!
Yes thats true lolchilla said:I had a annoying noise, seemed worse at around 20-30mph. Was going to swap the tyres round, but when I jacked the car up, it was fairly obvious that one hub was gone. i.e. the wheel wobbled.
So I guess if you swap the wheels you will find out either way, maybe![]()
