1 - 9 of 9 Posts
Is it possible that the 3 month old(2k miles) front bushes have failed again as the noise that went when these were replaced is back again?
ST200 baby
if they have been fitted wrong and split the rubbers then yes they could go tits up lol , do you know if they ere fitted right , were they ford parts?
Fitted by a small garage, look alright though. Not Ford parts,picked up when fetching some drop links. I perhaps should have had some poly bushes fitted
ST200 baby
Ya poly bushes are good mate , you can get them in a whole kit form for your car , but even with the ford parts or even copy parts they should work fine and last longer than 3 months mate , cant you go back to where you got them done from and see if they can replace them, maby you have a faulty set? i cant see it my self but they might replace them..
No chance, I brought them, they fitted them. I cant see the the local motor factor taking them back. Think i will just have to take the expense and get some poly ones fitted!
thewoody said:
What noise is apparent when they go?
Assuming I am right about this it is a harsh thud sound on mine when the suspension goes from extension to compression after going over speed humps
1 - 9 of 9 Posts
