I have connected to the car with my laptop and I have a couple of codes come up - does anyone know what they mean?
P1151
Definition type Definition
FORD Lack of HO2S Bank 2 Senor 1 Switches - Sensor at Lean Limit
P1518
FORD Inlet Manifold Runner Control Malfunction (stuck open)
Any help will be appreciated
M9G
Discussion Starter · #2 ·
Just been out and wiggled the connector for the front lambda sensor as the first fault mentioned oxygen sensor and the car seemed to go loads better, no kangarooing and the acceleration is great so hopefully all cure.
I did clear the codes in the ecu and wonder if this solved the problem and that the faults developed when I re-built the engine, i don't know if the car adjusts the running to compensate for the fault codes thus making the car run poor.
Not sure but will test for a day or two and then connect laptor back up and see if any faults appear.
M9G
Administrator
P1518
M9G
That one means an IMRC (secondaries) fault. The IMRC might be opening the secondaries upon startup. If the secondaries are constantly open the car will be sluggish at lower revs but will still have good power above 3200 rpm where secondaries usually kick in. My IMRC did this for a few weeks before it's demise.
How are you getting on with the Tekmate kit? I was really impressed with mine, they must have delivered yours quickly.
Hi
I bought the one from genden, remember the link you sent me.
Used their software and it had 2 faults which i cleared and that seemed to sort the problem
Tried using tekmate software with the cable i got but it wouldn't connect and I couldn't find anywhere in the tekmate software to change the port.
M9G
