thecuz said:
apprantly the manifolds are gas flowed (uim is painted silver), its got bigger injectors its supposed to have been chipped??
They are coilovers on the rear (not sure what make) and gmax shocks with koni springs on the front which is a bit of a strange combination I thought.
What is the paint? I need to get a little bit of rust sorted on the rear arches and a small scrape on the front bumper but dont know who will be able to match it.
I get people asking me about it all the time and saying its pretty special :} turns a lot of heads!
NOS is still in
got to get the bottle refilled. Have been too scared I might break it :whistling:
i didnt know about the manifolds, chip or injectors. it didnt have that when i knew the guy, maybe its been done since. have a look near the PAS reservoir, is there an aftermarket chip box there? if not it might have been bluefinned.
maybe one of the front coilovers or shocks had broke so its had those put on the front instead?
shouldnt really mix n match coilovers and normal springs, so it might be an idea to sort that out.
one of my photo's has the name and number of the place that painted it in crawley, maybe ring them and ask for the paint code. i wouldnt have thought its gonna be easy to get bits blown in though... but maybe they could sort it?
try www.nitrousoxidesupplies.co.uk for a refill, they will collect and redeliver the bottle refilled for you.
dont use the NOS in this weather because its so cold, there will be no pressure to blow the gas out of the tank. so all you will be doing is injecting extra fuel. you really need a bottle heater and a guage, get it up to about 900psi on the guage before use. then it will run perfect and hit you like a sledgehammer when it kicks in.
if you leave the bottle in the house overnight before use (not next to a radiator) it will be around 900psi. but once you've drove somewhere, parked up etc it will be stone cold again.
it might be an idea to get the nitrous system checked out that its all working before you go and use it. in case one of the solenoids isnt working or something, you could cause engine damage.
