Hi folks
as some of you might remember i have been toying with adding a socket to the boot of my ST line X hatch (2017 reg) but really dont fancy trying to pull the centre console apart to join to the wiring of the front or centre console sockets. i have one of those 3 way adaptor things which i would just attach to the side plastics, under the rear parcel shelf, if that makes sense?
so, my next thought was to go into the fuse box, use one of those piggy back things (take the fuse out, put in the addition, then fit the fuse to that, as per dashcam hardwire kits) in the fuse box (the one in the passengers footwell) then run the wires along the inner sills (under the trims) and through to the boot, and join to the socket im planning to use.
now heres the problem. the handbook (i only have the online one) doesnt tell me what fuse does either socket. a search online says fuse 10 for drivers aux power point, fuse 16 for the console one (i presume this is the one in the rear of the console) and if fitted, (estate only) fuse 17 for the boot one.
clearly i dont have the boot one as its a hatchback (hence part of the issue) but according to the manual my fuses are 'dual micro fuses', so i am assuming (as ive not taken one out) that they have a live centre pin, and each side leg is fused side to a different circuit (in which case my lighter sockets only seem to be fused at 5A, assuming the online info is correct)
so, are such piggy back things available (i havent found them on ebay etc yet)? could i (somehow) tap into the official power supply for the boot socket somehow (the wire isnt in the side panel as far as i can see) OR do i really HAVE to pull apart the console to get this job done? (trying to avoid that if possible)
sorry for the wordy post, but think ive got most of the details covered. for what its worth its to run a fridge/coolbox. tried to feed the cable through to the rear socket yesterday, as id done previously in the mk4 and the tape (same roll id used previously) came unstuck and legs were getting tankled up in it. thanks in advance
