1 - 2 of 2 Posts
Complete knuckle head as cars concerned so be basic with answers!
I blew the fuse (well think I did as there was a flash while I was attempting to connect the SATNAV and after that the lighter did not work after)Anyway I manged to change the fuse for the ;lighter and it works OK, but since then the battery warning light displays all the time and the heated front window and light warning buzzer do not work. I've checked the fuses for the Window but they are OK.
Is it just a coincidence that the alternator has developed a problem or are the two problems possible linked.
Also where is the fuse to check for the buzzer, if that is the problem for that not working.
Oh i better add that it is a 1998 1.8TD Mondeo.
1 - 2 of 2 Posts
