Hello
Looking for a bit of guidance.
Less than 12 months ago this previously reliable vehicle with only 107 thousand miles gave out with major fuel injection problems.( fuel pump ate itself and contaminated entire system ) After shelling out a fortune at local garage for new fuel pump, injectors, filter plus other ancillary items including tank removal and clean out. Fuel pump and injectors were Delphi factory recon parts
The car has from that time run satisfactorily with good economy and fuel performance only using Shell or Esso fuel as I was advised not to use supermarket fuel.
I had noticed on occasion recently that pulling away from junctions or standstill that the car was emmitting a cloud of smoke but not during normal driving. Exhaust emmissions checked ok for mot in March. Have now only covered another 7000 miles since overhaul.
Yesterday things got worse, the car now trails dark smoke and even worse starting off , judders at times on even throttle as would a petrol car with a slight misfire and also is a bit down on power. There are no lights coming up on the dash indicating a fault at this time.
One other thing, during a cold spell in January twice the car dropped into limp mode and was fault code diagnosed by garage as requiring a new turbo, however a second opinion taken from a man specialising a bit more in fuel injection and turbos correctly diagnosed it as a sticking turbo regulator arm which was dealt with at little cost and up till now no further problems.
My first thoughts (apart from setting the car alight) are to have a leak off test done on the injectors to see if any are the problem.
I would be pleased for any further advice.
Mike
Mike
