Fitted them today, dead easy to fit just had to pop the strut from the boot then strip clipped on and stuck with double sided tape. Very tidy and unnoticeable when fitted. No more dripping boot at last.
From what i can remember with this, the only way round it is a modified screen with the rubbers built in.darlofan said:Well the strips don't seem to be working!! Lots of rain over night and the water came pouring in, worse than before. Before the strips when i opened the boot most of the water flowed outside the car it was as the flow got weaker it started to come inside, this morning with the strips it almost seemed like the water cant get down the tunnel in the strips fast enough so backs up and consequently goes in the boot. I'm going to experiment with opening the boot slower to see what happens then. If not i'll be back to ford for my money back.
Must be a heck of a lot of standing water on he tailgate Darlofan. I see your parked uphill in your drive which is how mine is usually parked. Its persisting it down here are the moment and thoght I'd see how much water runs off the strips with a quick open of the talgate.darlofan said:Well the strips don't seem to be working!! Lots of rain over night and the water came pouring in, worse than before. Before the strips when i opened the boot most of the water flowed outside the car it was as the flow got weaker it started to come inside, this morning with the strips it almost seemed like the water cant get down the tunnel in the strips fast enough so backs up and consequently goes in the boot. I'm going to experiment with opening the boot slower to see what happens then. If not i'll be back to ford for my money back.
Ah, you did do it too!!shipmand56 said:Having had the infernal shower on opening the boot I also drilled additional holes in the plastic tailgate section and this really does seem to have made a big improvement - now I only get a few drips, nothing like what I had before.![]()
Hope you remembered to prop the boot open? I didn't and its surprising how heavy the boot is with only 1 strut supporting it!!All done now - just needed to lift the metal tab on the struts and they come off easily...
