Hi
I've had this issue for a while now, the Numberplate LED does not come on but it does work when voltage is passed through it.
boot switch is on same circuitboard and works fine. not sure if its related but the interior lights are also dont come on most of the time
all fuses have been checked
Anyone seen this issue before
Any help welcome
Calgacus
Have you looked at the spare wheel?
sounds weird, but the boot sides and wheel well can fill with water from the rear air vents, this could cause electrical problems as there is a fuse board and connectors behind the left side panel. Worth checking for water or loose wires in them.
  • Like
Reactions: Calgacus
Sorry for the very late reply...no excuse just not been online much. Thanks Master your suggestion was indeed correct, water had pooled in the wheel well as corrosion on the fuse board... This has been resolved and i have had no further issues.
I do however have another little issue i am tackling now. Both interior cabin lights in the roof lining will not light up.
for a while it was intermittent,then only the rear one would come on when doors open or button pressed.
Now both will not come on. Both bulbs replaced with known good ones. and the fuse tests fine. From what i can find online the fuse is the on in the passenger footwell ?
The strange thing is the front light has a button to disable the lights and when pressed the button lights up fine indicating its ok.... but no matter what i try i cannot get interior lights to work
This one is driving me crazy lol
Any advise much appreciated
Schmill
Calgacus, was this the fuse box on the left of the boot?
Where had it corroded, and is it easy to check? I already have the trim & insulation stripped of as I'm in the process of dealing with the water ingress too.
Every time I turn the lights on/off (and so the numberplate light would come on) the boot unlatches... ????
