1 - 11 of 11 Posts
being SUPRISED! (maybe)
Hmmm yes im inclined to think the same. If your pumping the pedal then im presuming youve got a 'soft' pedal to start with? Or u have a vacuum leak or somthing?
MEG Captain
dodgy servo or air in the system maybe , is the fluid level low in the reservoir , if all the pads are getting low i suppose it would be possible to have a really low level in it , can you hear any untoward sucking noises when you lift the bonnet , that would possibly be a vacuum leak so the servo would not work as well , a few things to go on :L
Couch Potato
The pedal doesn't feel as solid on the mondeo when the servo isn't working fully because of the torsional flex in the bar that joins the pedal to the servo (which is on the other side of the engine bay), plus if it's a leaky pipe you will be getting some servo assistance but not as much as you should.
1 - 11 of 11 Posts
