1 - 14 of 14 Posts
I first had this problem about two months ago but fixed it by topping up the brake fluid, cos I thought it might be caused by a low fluid level... but it's back, so here goes:
the handbrake/abs warning light comes on for (so it seems) no reason at all... this happens when:
1) turning quite fast (stays on while turning, then turns off again)
2) stepping off the brake at a traffic light (either turns off after about 2 seconds or stays on for about 10 seconds)
The brakes are working fine so far, it's not the handbrake sensor as far as I can tell... any ideas?
Before anyone says it, I'm gonna take it to Ford's asap, but I didn't have the opportunity to do that by now.. :thankyousign:
MEG Captain
the key for me is your point 1) , dodgy wire somewhere , where though i dont know , also have you checked the thickness of the pads ???? :L
Somebody told me that's a common fault among ford's, nothing to worry about, but I'm not so sure...
Haven't checked discs/pads, but the MOT man said the brakes were looking good 2 months ago, so I didn't think about that.
Just a thought, could it be a leak somewhere?
Thx for your input so far!
MEG Captain
has the level in the master cylinder reservoir dropped noticeably ???? , dont forget it will drop slowly due to the pads and shoes wearing :L
MEG Captain
okies , make sure you post back the result :L
That all suggests to me that the brake fkuid is low and the level is falling below the sensor level in turns and on take off.
MEG Captain
logical i reckon :L
Discussion Starter · #9 ·
I checked it today, and the fluid level is indeed low, though I'm sure I topped it up about 2 months or so ago, so I guess I'll have the hoses checked anyway, just to be on the secure side. It seems odd to me that it could possibly drop that much in that period...
I would check ALL the calipers/wheel cylinders - front and rear - for any fluid weeps: that is where the most likely source of any leak is. Failing that then the pipe work - especially the metal pipe work: carefully follow it wherever it goes, especially any that go over the fuel tank - common point of failure due to rust. Don't ignore the exit point at the bottom of the reservoir.
Discussion Starter · #11 ·
Yes, I heard about the corroding thing, I guess I'll have a word with my local garage about it. Gotta have to get the hoses for the windscreen washer fixed anyway before winter really sets in, guess it's time by now :D
1 - 14 of 14 Posts
