Hi all,
When I brake at slow speeds, say in traffic or approaching a junction, the brake pedal has a pulsing sensation coming from it and the braking efficiency drops off a little. Associated with the pulsing pedal is a pulsing/buzzing noise coming from the engine bay (I assume). Any ideas?
It was doing this for a while before I changed my discs and pads and also changing to larger V6 calipers. The brake system has been bled also.
Today, I checked the vacuum pipes from the Servo to the inlet manifold and they look ok. Also pumped the brake pedal until it got hard (ooer!) then started the car and it had the normal give in the pedal.
Can anyone recomend checking anything else? or have you had this problem? I would greatly appriciate any help I can get.
Thanks.
Thanks.
