1 - 10 of 10 Posts
Pedro 'Si Si I drive ze Coach'
Oh dear. I'm getting worried about a noise the cam belt on my mk1 is making........
It's ONLY on warm up and it's a kind of plastiky tapping noise. I've taken the top cam belt cover off and the noise stops so I reckon the belt is flapping slightly and touching the top cover.
The cars paperwork reckons that the belt was changed less than 50k miles ago.
What do you guys think???
mondeoman said:
Maybe the cover was re-fitted wrongly after the belt change and has warped a bit or something allowing it to touch the belt?
Yeah maybe.......funny it only does it on warm up. It's almost as if the tensioner is taking it's time to take up the slack in the belt :confused: :(
Slide said:
Had the same symptons a while back, turned out the tensioner was breaking up. Get it changed.
Oh bugger [email protected] I've just spent £50 on some new speakers :(
Still waiting to Wii
you're due anyway, and mine started slapping after 8,000 miles, so when you do it, you may have to retension it again.
Discussion Starter · #9 ·
James_McHattie said:
When cold the sprocketts are contracted - the belt slaps. When hot the sporcketts have expanded - belt ok.
Tighten it a mil or so.
http://www.jimmycricket.com/pages/cambelt.htm
When you say tighten it a mil or so do you mean the tensioner?? can you do this manually?? I thought it was all done by springs and automatic........or am I being dim :innocent:
1 - 10 of 10 Posts
