Hello. I have a Mondeo TDi 1997 MK2 body diesel.
I am about to change cambelt but for this year there are 2 different kits , Now I am very confused which kit I should get. Can someone tell me If my engine is the 97-00 type och the 93-97 type.
TDDI Buff
it shouldnt be listed like that it should be listed as 93-96 and 96-00 you want the later one all mk2's had endura De engine mk1'a had same engine theoretically but it was just called 1.8 diesel. the only real difference is the width of the belts i was told by a mechanic and theres only a few mm in it.
Thanx man! Did some research on my own and drew tha same conclusion, have now ordered the 97-00 belt kit , hope to get it before the weekend and see If i can change the belt this weekend. The difference I was told is that the 93-96 belt is 18 mm wide for the fuelpump while the later is 22 mm.
