how come the cams are so far out?
with the crank pin in eng is pinging.
on the secon mark vibrating(+ big jump on start).
it looks like there is no relation between the tdc and the cams locked position at all,
so where is the correct 0 degrees for the cams or where is the tdc?
(apparently the camshafts are reset when are locked)
