Are you talking front subframe bolts? You shld never use the bolts to jack up a subframe! You shld use a jack to lift the weight of the sframe to the underside of the body and then tighten the bolts. *(Called workshop best practise)
*Same goes for lowering sframe - you should fully support the sframe right up to the underside of the body, and only then undo the bolts, THEN lower the sframe on the jack.
You're not the 1st to make the mistake!
If it's front, then you have to cut open the floor to reveal the not-so-captive nut and ideally get it welded back. There's a guy on youtube who did it and I'll try to find his video.
