Hi, if your filter is full of diesel at the outlet spout, and the car still won't start, then that's not your problem. That primer bulb thing won't have sufficient draw to pull the fuel from the tank.. Also, some cheaper versions of that tool once diesel has passed thro' them seem to fail. - the one way valve just becomes open. . I've had Laser and Machine Mart ones do that. Get a can of diesel and some clear tubing. Rest the can on the top of the engine and connect the tubing to the 'IN' spout of the filter and the other end in the can of diesel. Use a turkey baster (or tool of your choice) to squirt some of the diesel into the pipe. Then see if it starts. Oh, and to make your battery last longer while cranking, pull out the LARGE yellow 60amp fuse, F8, from the fusebox next to the battery. This'll stop the glowplugs draining the battery every time you crank or turn on the ignition (they stay ON for 30 seconds every time you turn the key-inspite of the glowplug dash light going out after only a few seconds.)
