G
Guest
·hello,
i have a 1997 2.0 liter mondeo ghia hb. recently my car needed a maintenance, oil, oil filter, fuel filter, air filter have been changed. there was pinging under hard acceleration. they told me my crank sensor needed to be re-adjusted. anyways, i took the car back, everything was fine, no pinging at all and a huge improvement at the higher rpms. a couple of days later the idle begun to stuck at 1100-1500 rpm all the time and at crusing speed when i press the clutch, instead of dropping to idle rpm the car revvs up on its own to arbitrary revs between 2000 and 5000 rpms. keeps revving for a few seconds and then drops to its non-normal idle at 1100-1500rpm. what could be the reason for this problem?
