Can someone please help? When I baught my ST200 the CD changer was missing so I baught another one complete with all wireing & brackets, the advice I need is where does the cable run? Is it along under the centre console or down the sill? Cheers chaps!!!
Kev
mount the unit under the seat, wiring goes under the carpet along the inner sill line on the passenger side, upthe RH side of the fuel pump cut off switch, up along the cross beam (visible with glovebox removed) then down through the gap on the inside left of the radio hole then into the head unit. Best to remove the passenger seat bolts to improve the install. Remember to disconnect battery for 20 mins beforehand to dissipate the capacitor for the airbag system.
