MEG Captain
yes , but maybe not a black clock , could be silver iirc :whistling: :D
Where do we start,
1st you would have problems with fitting the unit in. There would be a lot to do.
2nd you would have problems with trying to get the updated air con control unit to work.(& a lot of parts to changeover.)
3rd the unit that you are looking at is from a Zetec model & it wouldn't fit the sony radio unit if you were thing of using for that. The sony unit needs a different center console for that.
With modifying the dash, & "new" center it might go, but then you would have problems with the air con control unit. The facelift models are all eletronic control where the pre facelift model is not. It's the fan switch which causes the problems it's like a mk2 control. Plus you would have problems with the electrics in trying to controling it.
Unless your good at electrics & you want your car off the road for a long time it's a non starter.
