What info do you need? The chip below the one with the label is the RAM.
May need to remove the label to see the other chip info unless the board has more data?
I am trying to figure out dies this chip need to have different injectors installed to try problem solve the car missing and over fueling. We are just trying to eliminate all items.
This chip was installed 10 years ago and not sure has car ran 100% as car was parked up and only taken out a handful of times.
Maybe better to start with a stock ECU. Otherwise you may need the car on a rolling road to see whats happening with the fuelling and ignition timings throughout the rev range.
A quick chat with a Cosworth specialist or two is probably worth doing.
